蓝牙连接上了,声音还是系统声音,请问怎么解决
Translation:
Bluetooth is connected, the sound is still the system sound.
Is Your connected Device listed in Settings>Audio?
You could try it with Pulse Audio Volume Control. It is a Tool to set up Audio Input and Output. You can install it with the Command:
sudo apt install pavucontrol
您连接的设备是否在 “设置”>“音频 ”中列出?
您可以用 Pulse Audio Volume Control 试试。这是一款用于设置音频输入和输出的工具。您可以使用以下命令安装它:参见上部命令
谢谢,搞定了
