Hello, I am using the Main Menu App to Customize my Icons from the web apps that I installed using Chrome. But every time I upload an icon with a transparent background there is still a black or white border around the icon, I even tried using a Image to Icon Convertor But the image did not show up. Please tell me how to fix this.
This is harder to tweak in Core than in Lite... but screenshots of exactly what you are trying to achieve would help a great deal.
In Lite, it would be a straight forward custom gtk.css
file placed in /.config/gtk-3.0
directory.
I figured it out. The icon it self is a SVG file so I had to find a png to SVG online convertor and it worked
You can convert right in the terminal on Zorin OS;
convert file.png file.svg
