Transparent feature issue
Nothing improve same issue
I have disable all the extension but still the issue persists
here it is but still the issue is there whenever i hover my down my mouse in lower the taskbar all play and those button appears
did you disable all extensions ?
and I see a in your taskbar a video player running
Is Brave installed as Flatpak or APT Package? Did You tried it with reinstalling Brave and/or the Zorin Taskbar? If Brave should be installed as APT Package the Command would be:
sudo apt reinstall gnome-shell-extensions-zorin-taskbar brave-browser
Also: Did You tried it with Firefox? Maybe it is a Chromium-related Issue.
