Hi guys,
I've been using Zorin OS 17.3 since December 2024 and never had any issues. Things started going wrong when I tried to install PipeWire and pavucontrol on my PC to pair two Bluetooth speakers. Could it be a conflict between PipeWire and PulseAudio? After rebooting, I ended up stuck at the tty1 console. I read another thread that suggested backing up my data and reinstalling Zorin OS from scratch. Does anyone know if there's another solution?
Check whether or not zorin-os-desktop is still installed. For some reason it has three pulseaudio packages set as a dependency in Zorin 17, so changes to the audio system may have unintended consequences. When I tried this in the past, I still got to my desktop somehow, but the zorin-os-desktop package had been removed. (I later found that despite being able to get to my desktop, it was in a bad state.)
Try sudo apt install zorin-os-desktop. If it's already installed, it might be broken, and you could try sudo apt install -f.
