I just noticed the option to turn on something called 'ubuntu pro' in 'Software & Updates'. I'd like to know what this is, if I should enable it and whether there are problems with it if enabled. Thank you.
Ubuntu Pro is a subscription service from Canonical (parent company making Ubuntu). Sine ZorinOS is based on Ubuntu, this message sometimes may slip in during updates. You don't need this and can safely disregard that promotional informative message.
Maybe this will help? Found it on Google.
Seems a nice workaround to change distro at a glance rather than downloading and applying it manually .
Wow so I could directly change to ubuntu? Glad I didn't enable it yet...I might out of curiosity later on though!
Thanks for all the replies!
