OS Name: Zorin OS 16
OS Type: 64 bit
Windows System X11
whfs@OptiPlex-790:~$ lshw -c video
WARNING: you should run this program as super-user.
*-display
product: Caicos PRO [Radeon HD 7450]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:01:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom
configuration: driver=radeon latency=0
resources: irq:30 memory:e0000000-efffffff memory:f1a20000-f1a3ffff ioport:3000(size=256) memory:f1a00000-f1a1ffff
*-display
product: 2nd Generation Core Processor Family Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
configuration: driver=i915 latency=0
resources: irq:29 memory:f0c00000-f0ffffff memory:d0000000-dfffffff ioport:4000(size=64) memory:c0000-dffff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
whfs@OptiPlex-790:~$ xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 8192 x 8192
VGA-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 798mm x 334mm
1920x1080 60.00* 50.00 59.94
1680x1050 59.88
1600x900 60.00
1280x1024 75.02 60.02
1280x800 59.91
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 60.00
832x624 74.55
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 60.00 59.94
DP-1 disconnected (normal left inverted right x axis y axis)
DisplayPort-1-1 disconnected (normal left inverted right x axis y axis)
DVI-1-0 disconnected (normal left inverted right x axis y axis)
