Unable to find "Festive Wallpaper Pack" for Zorin Pro
I received the nice email telling me that Zorin had created a "Festive Wallpaper Pack". It was available System Tools --> Software Updater; but I checked my software status and am unable to find the Festive Wallpaper Pack.
Then the email suggested that I needed to find "AptURL" and follow the on screen instructions; again no luck.
Then it suggested Zorin Menu --> Settings --> Background to select one of the new wallpapers; no luck.
Any suggestions?
thank you and Happy Holidays
Ken N9VV
Ypsilanti, MI USA
In Software & Updates, are you set to Main Server?
In terminal, please run:
sudo apt update && sudo apt install zorin-os-festive-wallpapers-2025
and that should install the wallpapers.
