Yes please try. I will be heading off now for sometime. I will check back later.
hey, it works.
i turned my computer off, then i remove my sata cable and then plug it in other sata ports. Then restart it.
THANK YOU VARY MUCH.
You're welcome.
I am glad I could help.
@im_atul_25 Can you please mark the post that helped you as the
Solution.
Click on the "..." under the post, then click on the "Solution" flag.
Thankyou.
YAA OFFCOURCE.
