hey, i am here with an issue.
after instelling zoren os in my pc, i unable to write anything on my other external 2tb hard drives.when i use to paste something a pop-up will apper and it says-ERROR WHILW COPIYING.The destinction is read only.even i can't able to create a single file on that hard disk.
i think that it is an issue of granting the permission of read and write,Then i also checked, it is correct, i already gave permission to read and write, but it can't works.
please help me to resolve this problem.
Is it a FAT32 partition? And is the size of the file you are trying to paste more than 4GB in size? Please remember FAT32 partitions can't hold files of size more than 4GB.
I have used that command multiple times and it did not cause any issue. Using it too many times on the same disk might cause a problem but I found it totally safe.
However, if you are still afraid to use it...You can use chkdsk in Windows.
The ntfsfix command should have worked. Other than that I know of the chkdsk command that works with windows. Can you please unmount and then mount the drive again? I still the think that the ntfsfix command worked.
