I have used zorin 15, 16, 17 and recently 18 all on the same hardware
in 17 there was a wierd stutter, about once per day the entire system would freeze up and even though its still registering input in the background (keyboard, mouse, window events, etc) there is no reaction to any of the input for 15-20s.
While irritating since it happened so seldomly and it would basically be impossible to replicate reliably, i didnt make a bug report, though i asked around it didnt seem like many ppl had the same issue.
Now moving to 18, the freeze up has a much longer duration and occurs anywhere from 1-3 times every 1/2hr now, so i am very unhappy.
On a multithreaded system, whatever event gnome is waiting for/processing shouldn't create a problem visible to the user.
I softly edited your post:
"No" corrected to "Now" for clarity.
Yes, Zorin OS 18 initial release has seen a lot of Gnome Crashing or Freezing woes.
17 is at least still supported with 17.3 being the latest point release.
this machine has NEVER had windows on it, yes secure and fast are disabled, as stated zorin from 15 up has been installed here so we are talking MULTIPLE YEARS with longer in 15 and 16 than 17 and 18 since 17 and 18 were upgraded so quickly and problems ONLY in the later versions!!!!
not offline, not sure what 'install method with nvidia drivers' (all caps) means
i do see that theres an update to 590 i need to do though, but honestly my gfx is so old it doesnt get improvements from driver updates anymore, it might even be losing it as they optimise for newer hardware
Mhh i installed this on an HP Compaq presario cq57 from 2011 and on an Laptop with an Rtx 5070 and the new Laptop ist performing worse than an Laptop from 2011 im still waiting for zorin 19 tof fix this
I am in a very similar situation. My current computer that the family primary uses has had Zorin since 15, 16, and 17 and it has a 1660 too.
I was having random unexplained issues that I was brushing off, mostly noticable with Firefox, but other software randomly too. I just could not figure it out. Then after running a RAM test, I realized it was bad RAM. For some reason both sticks went bad. I got new RAM and now the computer runs without any issues at all. That might be something to look into.
With new RAM, 17 is very, very stable with virtually no issues at all. All the minor issues I had in 15 and 16 were ironed out in 17. Zorin 17 Pro has been, hands down, the best OS experience I have ever had. Everything just worked, and the few issues I had, were easily fixed and most likely my fault for tinkering. So I had no worries going into 18.
However, I have also been having troubles with Zorin 18 Pro, both upgrading and from a fresh install. I have a feeling it is not so much Zorin per se, but Ubuntu LTS and Gnome.
For some reason this computer has issues with all distros that use Ubuntu 24.04 LTS base. Not sure what happened there. Things that worked just fine in 17, no longer work or do not work as well.
It was just one too many things not working properly for my main computer, so I just decided to reinstalled Zorin 17 Pro for the time being. I still got a year or so. I was able to get LMDE working without any issues.
Also, I have am finding I have having issues running Zorin 18 on older laptops that worked flawlessly with Zorin 17, but struggle with 18 more than I thought it would. Very strange. LMDE 7 also runs just fine and most likely will be the direction I am forced to go after 17 runs out.
It is a bummer because Zorin has been my go to distro for years now. It just worked. Zorin 18, or maybe really Ubuntu 24.04 and/or Gnome, is causing issues where I never had them.
Ubuntu 24.04 LTS was a bit of a rush job as they had to rewrite the whole system because of a SSH kernel problem. 24.04 LTS destroyed my 22.04 system completely when trying to upgrade.
after 20 years with Ubuntu, i still have the 04.10 Warty Warthog CD, i now use Zorin which seems to have ironed out most of the bugs and is running very well for me and thankfully no more snaps.
