Unlimited hotspot terminal commands for Zorin OS
i used to be able to run netsh int ipv4 set glob defaultcurhoplimit=65 in command prompt as an admin in windows 11 to get unlimited hotspot tethering.
would anyone know the if their is a command for terminal in Zorin OS to achieve the same thing?
thank you
sudo sysctl -w net.ipv4.ip_default_ttl=65
For IPV6
sudo sysctl net.ipv6.conf.all.hop_limit=65
Thank you!
