Today i noticed that my screen is slow when unlocking (annimation ?), is this normal ? i already reinstalled the nvidia driver and that did not fix it. Any ideas ?
I would have to test it... I do not log into Gnome unless wearing full body armor and have three therapists on stand-by... So, I have not noticed it on mine.
EDIT:
I just went ahead and tested it. I logged into Gnome, then used the Lock Screen. It was fast and perfect. No artifacts. After testing twice, I realized the reason why...
I am not using GDM. I am using xscreenlocker and lightdm.
Were you logged into Gnome instead of Cinnamon when you entered the command?
Arrow key down to the Enable Networking option in the recovery menu. Once enabled, back up to the recovery menu and arrow key down to drop to prompt.
Hit enter
then
Awesome... I was getting worried. One problem leads to another... And I am sorry. I took it for granted that you would remove the desktop by being logged into one that was not currently running.
I will try to remember to make a note of that in future when giving users a tip on removals.
Unlocking my workstation computer is slow for me as well. But I never blamed Zorin OS on that, because I know that the workstation is an old dual core machine, its slow, so its gonna take time to come out of the lock screen.
