Updater from Zorin OS Core 17 BETA to Zorin OS 17 Pro
Hi guys,
I bought Zorin OS 17 Pro and I want to upgrade from the Zorin OS Core 17 BETA to the Pro version. I'm using the Upgrade Zorin software.
I'm able to select Zorin OS 17 Pro and I can enter my Serial Key.
When I want to start the upgrade, I get this window
It turns for like 5-10 minutes and after I get this new window with an error.
There is the log errors
[CHECKING] Started
[CHECKING:Validating Upgrade Attempt] Started
[CHECKING:Validating Upgrade Attempt] Completed
[CHECKING:Checking Filesystem] Started
[CHECKING:Checking Filesystem] Completed
[CHECKING:Creating Necessary Files] Started
[CHECKING:Creating Necessary Files] Completed
[CHECKING:Adding GPG Keys] Started
[CHECKING:Adding GPG Keys] Completed
[CHECKING:Restarting Apt] Started
[CHECKING:Restarting Apt] Completed
[CHECKING:Simulating Flatpak Transaction] Started
[CHECKING:Simulating Flatpak Transaction] Completed
[CHECKING:Processing Apt Repos] Started
[CHECKING:Processing Apt Repos] Completed
[CHECKING:Updating Apt Repos] Started
[CHECKING:Updating Apt Repos] Retrying
[CHECKING:Updating Apt Repos] Fatal Error: { error-repo-download-failed:  }
[CHECKING:Updating Apt Repos] Failed
[CHECKING] Failed
[CHECKING:Restoring System] Started
[CHECKING:Restoring System] Error: { error-repo-download-failed:  }
[CHECKING:Restoring System] Completed
Can I do something to fix this?
Thanks!
The Zorin Upgrader Tool is still being processed for the release of Zorin OS 17:
Upgrades from Zorin OS 16 to 17 will be available in the coming weeks. Stay tuned to our newsletter to be the first to know when upgrades are enabled.
You can note some discussion on it here:
I'm already on Zorin OS 17 Core BETA. It says that Zorin OS 16 to 17 will be available in the coming weeks. There is no mention of Zorin OS 17 Core BETA to Zorin OS 17 Pro.
If it applies to Zorin OS 17 Core BETA, it's OK I will wait.
Thanks
I am reasonably confident that it does, since the underlying issue is the backports for Zorin OS 17. But you are right, this should be checked and verified - I will start that process, now.
Just used the upgrade tool to go from 17 core beta to 17 pro. Worked without any problems. Very nice. Bye Windows ... welcome Zorin ... loving it!
Crosslink:
Yes, some users may have earlier access or no troubles. Still, it is advised to wait until the ZorinGroup announces official Zorin Upgrader Tool support.
I retried later in the day and it's working now. I upgrade from Zorin OS 17 Core to Pro with my Desktop and Laptop without any troubles.
I marked your post as the solution since your thread is now solved.
I will continue to point out for all readers, however, that the official word from ZorinGroup on Official Zorin Upgrader support in 17 is not yet given.
Eagerness is understandable, patience is a virtue. :wink:
If a user does use the tool prior to official release, then runs into trouble later - the helpers on this forum may not be aware that you used the upgrader ahead of official release which may be the cause... So Please Disclose If You Used the Upgrader Prior to the Official Release.
