I'm already using Pop! OS, but I really like the way Zorin looks. Now, I was thinking about trying Zorin Core edition in a VM, then upgrading to Pro and swapping the drive into my laptop if I like the way things are going with it. Is there an easy way to go Pro without data loss?
Acer Predator Helios 300, if that matters.
Hi and welcome.
I would not know the straightforward answer to this, but before you undertake any new install/upgrade, what is crucial is that you backup all your critical data before attempting any upgrade. If you have customised any app settings these are held in hidden folders in your /home directory - to see them, press Ctrl +H and then select everything in your /home folder and paste to an external drive.
After installation copy everything from your backup into your /home folder once you have installed all the apps your current system holds so that the settings remain as you made them.
Theoretically, You can put a Drive with Zorin installed from one Machine in another. But I personally wouldn't recommend it. There are a lot of Variables, that hang on this.
It can work without an Issue, yes. But it don't have to.
Just to note core and pro version are pretty much the same, pro just has more preinstalled apps is all the price is to support the Zorin community. And to make sure there is no misunderstanding if you do buy Zorin Pro 18. its only good for that version If and when OS 19 comes out You WILL need to purchase a pro version of it if you want a pro version of 19
Yes I agree, Zorin OS has a very edel look!
I am using Zorin OS 18.1 Pro and enjoy it.
But first you could check the compatibility with your Acer Predator Helios 300 and other hardware you use.
To do that you can flash an USB stick, copy the Zorin OS 18.1 Core Edition ISO file on it and boot from it and then using the option "Try or install Zorin OS (modern NVIDIA drivers)" and then "Try Zorin OS" without installation. Maybe neccesary NVIDIA drivers are loaded?
Here you can check wether your hardware works properly specialy your NVIDIA GPU.
Please provide us more info about your Pop!OS linux system to see under which configuration your Acer Predator Helios 300 works properly, how good does it work under Pop!OS?
Go to Settings - System - Info - System Details or use neofetch and post it here.
From Brave AI to handle with care
Acer Predator Helios 300 – Pop!_OS vs. Zorin OS
Both run on the Helios 300, but there are important differences:
NVIDIA Drivers
- Pop!_OS : The NVIDIA ISO comes with pre-installed proprietary drivers – works immediately, no tuning required.
- Zorin OS: Drivers must be installed manually (GUI or
ubuntu-drivers). One user reported significant battery drain, which was only resolved by using the proprietary driver (not Open Kernel Module) and disabling the GSP firmware.
options nvidia NVreg_EnableGpuFirmware=0
options nvidia NVreg_DynamicPowerManagement=0x02
Kernel & acer_wmi
- Pop!_OS uses the System76 backport kernel (currently 6.18.x). Since kernel 6.8.6,
acer_wmi supports the parameter predator_v4=1, which activates the Mode button and fan monitoring on newer Helios models – this only works with Pop!_OS's more recent kernel.
- Zorin OS remains on the Ubuntu LTS kernel (5.15/6.8 depending on the version), which may result in the absence of these acer_wmi functions.
What DOES NOT work on either distro:
- Predator Sense (Fan Profile, Turbo Mode, CoolBoost) – no Linux version from Acer.
- RGB Keyboard – remains on the BIOS default (blue) unless using community kernel modules such as cleyton1986/predator-sense or the DKMS module from shipsar.in (supports PH315-52/53).
- NVIDIA Dynamic Boost – not available under Linux.
BIOS requirements (both):
- Disable Secure Boot**
- Switch RAID to AHCI (enable in BIOS with
Ctrl+S)
- Touchpad may change from Advanced to Basic
Conclusion for the Helios 300:
Pop!_OS (NVIDIA-ISO) is the simpler choice – GPU support out-of-the-box, a more recent kernel for acer_wmi features, and system76-power for power management. Zorin OS also works, but requires more manual driver work and offers fewer kernel features for Acer-specific hardware.
For fan/RGB control under Linux, the Linux-PredatorSense project (Rust + GTK4), which has been tested on the Helios 300 (PH315-52/53), is also worth considering.
