Hello to all Linux lovers
I have Zorin 16.3 Pro version on my system
Due to wireless network problems, can I upgrade the current version of 16.3 to 17 offline by having the ISO file of professional version 17?
As you already have the Pro version of 16.3 I would contact Team Zorin directly, as technically it is a Pro support question and one of the advantages of having Pro is you get Technical Support for the prime machine it is installed on.
thanks alot swarfendor437
