Have Pro Ver 16. I see that Ver 16.1 can be updated to Ver 16.2 through
the program's Updated. Can this also be accomplished from Ver 16? Thank you
Yes, it can.
You can use the Update software or in terminal run
sudo apt update && sudo apt dist-upgrade
You shouldn't have any issues there at all. It's in the 16.x series, I'd be surprised if you had issues honestly. Unless maybe you've made sweeping changes somehow.
All good - not sure what happened - thanks for the responses
Glad to hear things went ok for you! Maybe Windows was trying to win you back?
