I've installed Zorin OS Core, if I buy Pro how can I upgrade? Do i have to reinstall the system? Or is there a way how can i keep my files and upgrade.
Hello and welcome to the forum ![]()
Yes to the both questions.
I have been running Zorin 16 Core beta and recently updated to Zorin 16 Pro. Clean install is the only way to do it.
To keep your personal settings and files, save your Home directory to a safe place before wiping the disk for a new installation.
You came from beta, i have read somewhere you can just update to pro within the core version
While you can install some apps and customization to make Core to be similar to Pro version, there is no direct upgrade from Core to Pro.
okey thank you
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
