hey how can i check that my laptop supports usb 3.0 or usb 3.1 pendrives or not
because i have to buy one for laptop if it not supports usb 3.1 then i'll think of usb 2.0
That's pretty much it.
Be warned:
Unscrupulous manufacturers have been using Blue USB ports on 2.0 ports. Simply, there is no actual Standard or Law to be enforced that Blue actually means 3.0
But by mismarking the 2.0 as 3.0, the shady manufacturers get more sales.
Run the following command in terminal:
sudo lsusb -v | grep -i bcdusb
Looks like you have one 3.0 port. Look your computer over and if you see One blue usb port, then you have confirmed it.
As for the error you got... I would check over your fstab file if I were you. Check your disk integrity with a S.M.A.R.T. test, as well.
bro all ports are of blackish in colour
and pls help me out with pendrive concern
i want to buy a pendrive i was thinking of usb 3.1 pendrive which i was getting in a good offer so that's why i am asking is that usb 3 pendrive will be usable for me or not
