USB-C Monitor not detected correctly when it powers up
Is there a way I can run a command when the external USB-C monitor powers up?
( xinput map-to-output 12 DP-1-0)
The problem is that the monitor powers down every time Zorin blanks the main screen. When I move the mouse, I have to run the command manually.
Thanks.
This may help?
If not please give us your machine spec's/model.
Also please show the results from the below commands, with the external monitor working.
xrandr
sudo lshw -c video
Keep us informed.
Could i ask you to please adjust your profile to reflect the Zorin OS your using, ( Core/lite/etc)[HOW TO] Indicate Zorin Edition in profile
