The above article might be helpful.
Have seen many websites through about that problem. So can not remember any particular pages. But the ones I find it were a bit old (1-2 years old)
Yes it could be very interesting. But do not quite understand how to do it?
Hi now I have bought a display cable. So now I have 2 monitors set to computer one with HDMI and the other with display port. One now it can not see the screen with HDMI? What do I need to do to make it work with 2 screens? I am running on Zorin OS 15.3 with latest update
In terminal, let's try
sudo dpkg-reconfigure gdm
Select GDM3
Reboot.
If no change, then in terminal,
sudo nano /lib/systemd/system/gdm3.service
Find this line:
ExecStartPre=/usr/share/gdm/generate-config
Replace it with this one:
ExecStartPre=/usr/bin/xinit /usr/share/gdm/generate-config
In terminal,
sudo nano /etc/X11/Xwrapper.config
Add the following line, then exit and save as original title
needs_root_rights=yes
If still no good, try:
sudo apt install intel-gpu-tools
intel-virtual-output
Reboot
A post was split to a new topic: USB connected display issue
