as user Elegant_Emperor has said the best way to use a usb is to format with something like gparted use MS-DOS formatting scheme and use it as a FAT/FAT32 filesystem which is what most USB's come formatted as out of the box.
I suggest logging into the user who formatted the drive right click on the file > properties or highlight it and use ctrl+i and go to the permissions tab and make sure all groups are set to create and delete files.
You might find that it only has user1 able to access files or in your case not able to see mounted drive so you could change the permissions before you wipe the drive and see if that works.
If it doesn't copy the file over in the user who formatted the USB drive then reformat drive with filesystem above and then copy file over and check permissions of the file when on the USB drive.
If nothing above works feel free to come back to us
we'll be here but hopefully it will be fixed
