When You set the GP106 Audio to off and then enable the Sound Blaster Audio what Options do You have then on the ''Output Devices'' Tab?
When the issue occurs I can only see the Dummy Output when I disable the GP106 Audio.
I really don't think this is an audio issue. The soundcard sometimes fails to be recognized. Is there a way to check whether it was loaded or a way to force to reload the card on startup?
