Hi, i have a problem concearning the fact that i have an usb wifi external antenna that works on my zorin profile, but whenever i start my VM (virtualbox) i the option to setup the USB input is unavailable because it can't recognize any, so how can i use wifi on my VM using kali linux, should i still use the antenna in any way or have you guys any other idea?
You may need to add the device in the Virtual Box 'Details' page - plus, don't enable USB 3.0 - it doesn't work in Virtual Box, only USB 2.0! Personally I would advise you give Virtual Machine Manager a try - much more better than Virtual Box!
