Wondering if I can use my Zorin 16 Home partition when installing Z_17 Pro.
The Current Zorin OS Pro contains the Gnome desktop and your Home 16 partition will contain XFCE configurations.
You should be able to use it, yes - but your configurations will not work.
You can
mv ~/.config ~/.config-bk
to back them up, but set to default configs.
OK Thank You; worst can happen is have to install again.
The Home folder contains your personal data, pictures and documents so do be sure to backup your data, please.
