Using Dark Theme On GDM and Lock Screen
I want to use ZorinBlue-Dark on GDM and Lock Screen. I like my themes similar to my desktop theme.
System Specs:
OS: Zorin OS 16 x86_64
Host: Aspire S3 1.15
Kernel: 5.11.0-27-generic
Uptime: 1 day, 17 hours
Packages: 2381 (dpkg), 1 (flatpak),
Shell: bash 5.0.17
Resolution: 1366x768
DE: GNOME
WM: Mutter
WM Theme: ZorinBlue-Dark
Theme: ZorinBlue-Dark [GTK2/3]
Icons: ZorinBlue-Dark [GTK2/3]
Terminal: gnome-terminal
CPU: Intel i5-2467M (4) @ 2.300GHz
GPU: Intel 2nd Generation Core Processor
Memory: 1526MiB / 3784MiB
Thank you
I havn't tried this on Zorin, but maybe this can do it: GitHub - juhaku/loginized: Gnome GDM Login Theme Manager. Easy and Fast Login Theme Manipulation</
No cigar, I just tried it. It doesn't work on Zorin OS
This is very sad, I remember Zorin Os 15 doesn't do this.
No solution? :frowning_face:
I wish I knew. I would like to change the background picture.
This... actually... is what confuses me about resistance to LightDM.
I have never had LightDM glitch or fail me... Never had to reinstall it due to it suddenly being corrupted, as I had with GDM3 several times. Or an update mess it up, like GDM does.
It's configuration is easily set in just One File. It can use any system theme you want, any user theme... It can use a theme independent of the theme you normally use after logging in. Any background picture, any color, have a menubar or not have one... have a panel or not have one...
It can have any background image you want in the menubar - including it being opaque, translucent, transparent...
And most of the configuration can be set using a handy GUI with settings and buttons.
You can, I remember I answer a forum on it before. Sorry I can't find the forum I answered I think it's from my other account(I forgot the password).
My Old Account:
Kedric Pon
Long time watcher, first time poster, hello!
I've encountered exactly the same headaches with GDM3 as everyone else looking to customize it seems to have.
So I followed your advice, and tried out LightDM!
Logged in and immediately had Gnome complaining at me that I was no longer able to lock my computer because GDM wasn't my active Display Manager.
You got a workaround for that?
I have more experience with LightDM with other distros, and how Byzantine GDM customization is really ticks me off.
Can you install the xscreensaver package to provide a package that can lock the screen?
sudo apt install xscreensaver xscreensaver-data xscreensaver-data-extra
Open your keyboard settings and create the keyboard shortcut that is not the same as the GDM lockscreen shortcut. The command is xscreensaver-command -l
If not using Chrome or Chromium, you may try an Extension: LightDM Lock Screen - GNOME Shell Extensions
I have never used it... I cannot vouch for any gnome-extension...
Turns out gnome-screensaver does that, and it all works out the box.
Couldn't get light-locker to work at all.
However gnome-screensaver only works on X. Not Wayland (which was what was tripping me up on a few things)
(Yeah, the shipped gnome-screensaver will segfault if you try and lock the screen under Wayland)
All I've got to figure out now is how to get gnome-screensaver daemon running without having it in my user autorun.
If you are using Wayland, that would explain the trouble. I can only recommend not using Wayland as it comes broken out of the box.
The concept behind Wayland is a good one. But it is incomplete. Many apps do not work with Wayland at all.
Yeah, I (personally) use X11 by default, plenty of apps hate Wayland.
Still exploring other options, but I have a fallback that I know works now
(LightDM, GDM and gnome-screensaver)
Gonna check out xsecurelock (by Google) and swaylock as well.
Love linux for this kind of thing, turns into a project that can keep you engaged. :slight_smile:
I do wish that Zorin (or the GDM3 devs) would give us a nice configuration tool for their login screen though...
Update, xsecurelock is very nice and very basic (the way I like it), however GNOME is a pain in the rear-end when it comes to using not-gnome stuff.
So the system won't lock on wake from suspend and Super+L won't work unless I set a custom keybind.
Hilariously, calling dm-tool lock takes me back to the LightDM greeter (so I never needed gnome-screensaver in the first place), but GNOME doesn't use dm-tool lock it does it's own witchcraft to call either GDM3's lock or gnome-screensaver if the latter's daemon running.
Update 2
Wow... not using gnome-screensaver is a gigantic pain...
GNOME only wants to work with GNOME things. If I want to use light-locker, or xsecurelock or anything that isn't GDM or gnome-screensaver I have to sacrifice something. Like automatic locking on screen blank, or lock on resume from sleep.
Gnome devs, why can't I just tell gnome to use a specific command for locking things instead of having to try and hack something together?
Update 3 - an aside
Here's the hilarious thing.
If GDM3 just let me change my login screen wallpaper, I'd not have fallen down this rabbit hole.
Update 4
The lock button in the start menu... invokes lightdm...
but Super+L, Sleep and Screen Blank invoke some kind of dbus call.
Who designed this...
Update 5
Spun up my own thread because I technically hijacked this one, oops
I bumped the excellent write up to Tutorials and Guides in hopes it makes it more easy to find for others. In General Help, it will quickly get swamped and buried.
Well, that's certainly my intro to this forum that I didn't expect...
Thank you for that :slight_smile:
Now I just need to figure out how to get what I want working, lol
