I see your points and I certainly can understand your view. I agree with you more than we disagree, I assure you.
To compare notes....
- This is not a tutorial or guide. It is in General Help.
- There was no provided answer or solution that users can follow to illegitimately skirt copyright or copyright protections.
- This thread does not contain any digital data, protected or not. It discusses a user accessing his own copyright without disclosing the names of the files or the file contents. No one can download or access the data in question or even knows what that data is publicly.
The above factors are important. And they are different than a guide that specifies a product by name and then tells how to bypass protections step by step.
I had edited my post above while you were typing your reply. So please be sure to read it over as it may provide more clarity on viewpoints.
My own opinion is that this thread is not illegal - but it really toes the line. It gets very close without quite crossing over that line.
And as I said above, I probably would have closed the thread had I seen it at its beginning. It may have worked out ok that this did not happen... since we now learn that copyright owners are protected against removing DRM on their own content.
Now, after the fact, a friendly warning and a reminder to stay diligent is the best we can do.
That being said:
Tagging this for review from @AZorin and @zorink - the ZorinGroup Developers as they may well agree that this thread needs to be truncated or redacted.
In the meantime:
This is true as a glaring oversight on my part.
I took a hiatus from the forum and left it with one Moderator Short. I gave no warning... I just kind of hit some limit and took off for a while.
It is known that @Storm is busy writing as an author- that @337harvey is also overwhelmed with things...
This thread is a bit of a slap in the face to me, as well - to be more considerate and forthcoming. To plan a hiatus prior to reaching any limits and more intelligently manage my time here.
