I have just installed fresh Zorin OS on my PC computer. I am using the TP-LINK Archer T2U V3 (te7t2uv3) as my default device to connect to the internet. It was working fine on my Windows before on the same machine so it is not connected to the hardware issue.
I have installed the Realtek driver: https://github.com/aircrack-ng/rtl8812au
My PC is recognizing the adapter but the system cannot find any WiFi network, just showing the loading circle with "No networks" text under infinitely.
I have noticed something strange, the netstat -i command gives me:
The last name is the name of my adapter and it seems to be bugged, i had no idea what does it mean, unless i typed: nmcli device status, which gave me the output:
DEVICE TYPE STATE CONNECTION
enp8s0 ethernet connected Wired connection 1
\3207E\231-\307 wifi unavailable --
lo loopback unmanaged --
And there as you can see is the full interface name of the adapter (\3207E\231-\307). I don't even know if naming causes the problem or something else.
I spent many hours on this problem, did some research and tried to fix this but I am now faithless and tired. Anyone has a similar problem or maybe know what causes the issue?
I have found this and tested already, does not helping. Btw there is no dkms-install.sh file in this repo anymore. I have copied it from another but also didnt worked for me. But thank you anyway
Bus 002 Device 008: ID 2ea8:2122
Bus 002 Device 010: ID 04e8:6864 Samsung Electronics Co., Ltd GT-I9070 (network tethering, USB debugging enabled)
Bus 002 Device 003: ID 2357:011f TP-Link
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 09da:7f72 A4Tech Co., Ltd.
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
