Very Rocky First Experience
I will preface this by saying I have been distro-hopping by trying different distros through a virtual machine. As I am currently trying to potentially move to Linux from Windows. Most of the distros were very meh to me except Ubuntu which I liked right from the start. But then the very last one I tried caught my eye, Zorin.
It was extremely elegent looking, the UI reminds me of something from Windows 7 era. And I love it. So with that, I decided to get off the virtual machines and try zorin for real this time...
Before doing so I made sure to look into exactly how I was going to do this, as I wanted to still be able to boot into Windows for now incase I do not actually like it like I thought I would. I needed to be sure that I could secure boot AND dual boot.
So here we go, I boot into the Zorin OS flash drive I made via balena etcher and I start to see my first issue. Albeit, I have had a similar experience on Windows but basically I have a 3 monitor setup, one on the left, one in the middle and one on the right. The one on the right is a bit different as it is vertical. Now, I have this issue where my far right monitor always ends up showing up as labeled "1" followed by my middle as "2" and the left one as "3". Because of this I have to basically move the installation box around until I can properly see it on my main monitor in the middle.
This wasn't really that big of an issue, yet.
I end up going through the installation up until it asks me how I'm going to partition everything to get it set up. This is the part that I believe screwed me because I read mixed things about it. But basically I selected my secondary SSD as I thought installing alongside Windows was probably not a good idea on the same drive, but then I see also the option to choose which drive will install the bootloader GRUB onto. From what I read, you should install it on the same drive as Windows is using so that you don't have two separate bootloaders on two separate drives.
This is where my first major issue came in.
After the installation finished, but right before rebooting, I receive an error message that a fatal error has occurred and that GRUB could not be installed. Uh oh...
Low and behold when I reboot the PC, zorin is nowhere to be found in my boot devices. I'm not sure what exactly happened here but I basically found a way to install GRUB through the terminal by opening it in the live environment off the usb.
Okay, fine whatever, I got it to work. I don't really mind.
That's when my second issue came in. Upon booting into zorin for the first time, I see that my far right most monitor that is in vertical(portrait) orientation is the one that the login screen decided to show up on. Great...
Not only that, the image is flipped horizontally so I have to maneuver the mouse and try to login properly.
For the next rest of my day I troubleshooted and troubleshooted and tried pretty much everything possible to have the login screen default to my main middle monitor to no avail. Except eventually, at my wits end, I had a LLM(chatgpt) and yes I know I shouldn't be using AI for stuff like this, I had it create a script for me that would essentially turn off the right monitor so that it would force the login screen to display on my main middle monitor.
After all that, finally... I fixed two issues that were pretty bad. But man the fact that I had to do all this just to begin using zorin or Linux in general for that matter it's extremely frustrating, I'm not exactly sure if you guys have any advice on if there's a better way I could have done things but it has been stressful as hell!
I'm not trying to bash on Linux or zorin in general but when I'm trying to do something as simple as installing the os I feel like I shouldn't have to go through these kind of hoops.
Thank you for coming to my Ted talk. :blush::+1:
Hi and welcome to the forum.
I'm not sure if you are actually seeking help for your screens issue, but I definitely see your post as being feedback on your experience. So I have moved this thread to "Feedback" Section.
If you have a specific question remaining about configuration of multiple screens on Z18, then do post again in the General Help section.
Becuase of the Monitor Thing: I have now a 2 Monitor Setup and had the ''Issue'' that the wrong Monitor was labeled as 1. Then, I understand that this was because the Ports on my Mainboard had a specific Order. So, I had to switch to get the right Monitor to Port 1. This is similar to a TV. There You have numbered Ports, too.
yes... I learned this after. Indeed my right monitor is set to "1" while my main as "2" and so forth. It is just kind of dumb though because coming from windows, windows is able to change the main monitor for login once you set the monitor as main display. Zorin should add a change like this too...
If you are looking for something that looks close to Windows 7 then I would give Q4OS a try with it's LookSwitcher (similar to Zorin Appearance). The Look Switcher offers many different Windows themes, even XP!
I know what you're talking about, and this is a known "issue". I use quotes because, if you go ask any Gnome developers, they would say this is intentional. I BELIEVE if you copy
~/.config/monitors.xml
to
/etc/xdg/monitors.xml
after you've setup your monitors the way you like, that should copy those settings to your Login screen as well (these locations may have changed since I've done this last, but that's running off memory mostly). This should absolutely be a setting in the Gnome Settings window.... but good luck convincing Gnome of that.
The Command is:
sudo cp ~/.config/monitors.xml /var/lib/gdm3/.config/
I use that everytime I need it, too. And I agree: That should be something that is available in the Settings.
For some reason this never worked for me even after changed my monitor settings
The Thing with this is a bit tricky. When You use the default Monitor Settings this Files doen't exist. You have to change the Settings and keep them. Then change back and then the File should exist.
Ohhh, my brain hurts, why do they make it so convoluted? If we want more people to use Linux, we need to stop doing things so convoluted. If my brain hurts to do a task, then its too much. I feel for the OP, it shouldn't ever be that hard.
The easiest thing would be when there would be in the Settings an Option for the Login Screen where it would be possible to set it up with Resolution, Scale Background Picture etc. But on Gnome this will not happen.
