Hi,
can anyone suggest please a nice video to audio converter with gui for zorin?
I want to do video's to mp3 or AAC
I used to use Any Video Converter Free: Convert Videos to Popular Formats and Edit Videos for Free (windows)
Thanks
Hi,
Thanks
hi,
check following apps
I'm reluctant to use current releases of Audacity as it gathers info on what you are doing with the program. I would give WinFF a try. It is one of the apps I recommend in the Unofficial Manuals I wrote for Zorin 15 and 17.
Thanks for that, however that link is 404
I found it here I think but as there is so many I have no clue which one?
You don't need to download anything - the application itself is in the Ubuntu repository, and you can install it with the following command:
sudo apt install winff
