Once I start any .iso on Virtualbox 6.1 on Zorin 7.2.0 it pops up error window. Need help to resolve this issue.
It seems that VirtualBox 6.x is not compatible with a recent update made on the Linux kernel. The best fix for this is to upgrade directly to VirtualBox 7.x. Unfortunately, this package is not offered in the default repositories so you'd have to make this manually.
Please check this thread on how to install it:
To avoid confusion in the future, I edited the title from "Zorin 7.2.0" to "Zorin 17.2.0", which I assume is correct.
