Hello, I am a long time user of ZorinOS and have found it to be the most stable Linux distro out there. However, I have continually run into issues with running VM's through virtualbox. I can't figure out what is going wrong and it is beginning to get frustrating. It's one of the few things (very few) that doesn't work on Zorin in my experience.
I won't go into my past issues but will post them on the forum if they come back to bite me. Currently, I am trying to install windows 11 in a VM. I have tried multiple different configurations, ensuring that I have 8+ gigs of RAM and 6+ cores. Each time I try and boot it, it fails.
FYI: I was trying to install it as if it was a Linux distro instead of windows. I have tried it past, letting virtualbox choose windows as the OS type.
Here is the last bit of the logs.
00:00:08.176806 /PROF/CPU0/EM/ForcedActions 0 times
00:00:08.176809 /PROF/CPU0/EM/Halted 0 times
00:00:08.176811 /PROF/CPU0/EM/NEMExec 0 ticks/call ( 0 ticks, 0 times, max 0, min -1)
00:00:08.176813 /PROF/CPU0/EM/NEMExecuteCalled 0 times
00:00:08.176816 /PROF/CPU0/EM/RAWTotal 0 times
00:00:08.176818 /PROF/CPU0/EM/REMTotal 0 times
00:00:08.176823 /PROF/CPU0/EM/RecordedExits 2 times
00:00:08.176826 /PROF/CPU0/EM/Total 2629833711 ticks/call ( 2629833711 ticks, 1 times, max 2629833711, min 2629833711)
00:00:08.176830 /PROF/CPU0/VM/Halt/Block 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:00:08.176833 /PROF/CPU0/VM/Halt/BlockInsomnia 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:00:08.176837 /PROF/CPU0/VM/Halt/BlockOnTime 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:00:08.176840 /PROF/CPU0/VM/Halt/BlockOverslept 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:00:08.176843 /PROF/CPU0/VM/Halt/R0HaltBlock 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:00:08.176845 /PROF/CPU0/VM/Halt/R0HaltBlockInsomnia 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:00:08.176848 /PROF/CPU0/VM/Halt/R0HaltBlockOnTime 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:00:08.176850 /PROF/CPU0/VM/Halt/R0HaltBlockOverslept 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:00:08.176853 /PROF/CPU0/VM/Halt/R0HaltExec 0 times
00:00:08.176856 /PROF/CPU0/VM/Halt/R0HaltExec/FromBlock 0 times
00:00:08.176860 /PROF/CPU0/VM/Halt/R0HaltExec/FromSpin 0 times
00:00:08.176863 /PROF/CPU0/VM/Halt/R0HaltHistoryCounter 0 times
00:00:08.176867 /PROF/CPU0/VM/Halt/R0HaltHistorySucceeded 0 times
00:00:08.176870 /PROF/CPU0/VM/Halt/R0HaltHistoryToRing3 0 times
00:00:08.176872 /PROF/CPU0/VM/Halt/R0HaltToR3 0 times
00:00:08.176875 /PROF/CPU0/VM/Halt/R0HaltToR3/FromSpin 0 times
00:00:08.176877 /PROF/CPU0/VM/Halt/R0HaltToR3/Other 0 times
00:00:08.176879 /PROF/CPU0/VM/Halt/R0HaltToR3/PendingFF 0 times
00:00:08.176881 /PROF/CPU0/VM/Halt/R0HaltToR3/PostWaitNoInt 0 times
00:00:08.176884 /PROF/CPU0/VM/Halt/R0HaltToR3/PostWaitPendingFF 0 times
00:00:08.176886 /PROF/CPU0/VM/Halt/R0HaltToR3/SmallDelta 0 times
00:00:08.176888 /PROF/CPU0/VM/Halt/Timers 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:00:08.176892 /PROF/CPU0/VM/Halt/Yield 0 ns/call ( 0 ticks, 0 times, max 0, min -1)
00:00:08.176896 /Public/NetAdapter/0/BytesReceived 0 bytes
00:00:08.176899 /Public/NetAdapter/0/BytesTransmitted 0 bytes
00:00:08.176902 /Public/NetAdapter/0/e1000 0
00:00:08.176905 /Public/Storage/PIIX3IDE0/Port0/QueryBufAttempts 0 count
00:00:08.176912 /Public/Storage/PIIX3IDE0/Port0/QueryBufSuccess 0 count
00:00:08.176915 /Public/Storage/PIIX3IDE0/Port2/QueryBufAttempts 0 count
00:00:08.176917 /Public/Storage/PIIX3IDE0/Port2/QueryBufSuccess 0 count
00:00:08.176920 /SELM/LoadHidSel/GstReadErrors 0 times
00:00:08.176922 /SELM/LoadHidSel/NoGoodGuest 0 times
00:00:08.176925 /TM/CPU/00/cNsExecuting 2327 ns
00:00:08.176928 /TM/CPU/00/cNsHalted 0 ns
00:00:08.176930 /TM/CPU/00/cNsOther 198291 ns
00:00:08.176933 /TM/CPU/00/cNsTotal 200618 ns
00:00:08.176935 /TM/CPU/00/cPeriodsExecuting 2 count
00:00:08.176937 /TM/CPU/00/cPeriodsHalted 0 count
00:00:08.176939 /TM/CPU/00/pctExecuting 0 %
00:00:08.176942 /TM/CPU/00/pctHalted 0 %
00:00:08.176945 /TM/CPU/00/pctOther 0 %
00:00:08.176947 /TM/CPU/pctExecuting 0 %
00:00:08.176951 /TM/CPU/pctHalted 0 %
00:00:08.176954 /TM/CPU/pctOther 0 %
00:00:08.176957 /TM/MaxHzHint 0 Hz
00:00:08.176959 /TM/PIT/Handler 0 ticks/call ( 0 ticks, 0 times, max 0, min -1)
00:00:08.176961 /TM/PIT/Irq 0 times
00:00:08.176965 /TM/TSC/offCPU0 0 ticks
00:00:08.176967 /TM/VirtualSync/CurrentOffset 0 ns
00:00:08.176970 /VUSB/0/cUrbsInPool 0 count
00:00:08.176973 ********************* End of statistics **********************
00:00:08.177020 VUSB: Detached 'HidMouse' from port 1 on RootHub#0
00:00:08.178142 NAT: Zone(nm:mbuf_cluster, used:0)
00:00:08.178429 NAT: Zone(nm:mbuf_packet, used:0)
00:00:08.178435 NAT: Zone(nm:mbuf, used:0)
00:00:08.178439 NAT: Zone(nm:mbuf_jumbo_pagesize, used:0)
00:00:08.178682 NAT: Zone(nm:mbuf_jumbo_9k, used:0)
00:00:08.178850 NAT: Zone(nm:mbuf_jumbo_16k, used:0)
00:00:08.178914 NAT: Zone(nm:mbuf_ext_refcnt, used:0)
00:00:08.178949 E1000#0: Interrupt attempts: 0
00:00:08.178952 E1000#0: Interrupts raised : 0
00:00:08.178954 E1000#0: Interrupts lowered: 0
00:00:08.178956 E1000#0: ICR outside ISR : 0
00:00:08.178958 E1000#0: IMS raised ints : 0
00:00:08.178961 E1000#0: Interrupts skipped: 0
00:00:08.178964 E1000#0: Masked interrupts : 0
00:00:08.178967 E1000#0: Early interrupts : 0
00:00:08.178970 E1000#0: Late interrupts : 0
00:00:08.178973 E1000#0: Lost interrupts : 0
00:00:08.178976 E1000#0: Interrupts by RX : 0
00:00:08.178978 E1000#0: Interrupts by TX : 0
00:00:08.178980 E1000#0: Interrupts by ICS : 0
00:00:08.178983 E1000#0: Interrupts by RDTR: 0
00:00:08.178986 E1000#0: Interrupts by RDMT: 0
00:00:08.178989 E1000#0: Interrupts by TXQE: 0
00:00:08.178992 E1000#0: TX int delay asked: 0
00:00:08.178994 E1000#0: TX delayed: 0
00:00:08.178998 E1000#0: TX delay expired: 0
00:00:08.179000 E1000#0: TX no report asked: 0
00:00:08.179002 E1000#0: TX abs timer expd : 0
00:00:08.179004 E1000#0: TX int timer expd : 0
00:00:08.179006 E1000#0: RX abs timer expd : 0
00:00:08.179008 E1000#0: RX int timer expd : 0
00:00:08.179010 E1000#0: TX CTX descriptors: 0
00:00:08.179013 E1000#0: TX DAT descriptors: 0
00:00:08.179015 E1000#0: TX LEG descriptors: 0
00:00:08.179017 E1000#0: Received frames : 0
00:00:08.179019 E1000#0: Transmitted frames: 0
00:00:08.179021 E1000#0: TX frames up to 1514: 0
00:00:08.179023 E1000#0: TX frames up to 2962: 0
00:00:08.179025 E1000#0: TX frames up to 4410: 0
00:00:08.179027 E1000#0: TX frames up to 5858: 0
00:00:08.179029 E1000#0: TX frames up to 7306: 0
00:00:08.179032 E1000#0: TX frames up to 8754: 0
00:00:08.179034 E1000#0: TX frames up to 16384: 0
00:00:08.179036 E1000#0: TX frames up to 32768: 0
00:00:08.179038 E1000#0: Larger TX frames : 0
00:00:08.179040 E1000#0: Max TX Delay : 0
00:00:08.179438 GIM: KVM: Resetting MSRs
00:00:08.182132 Changing the VM state from 'DESTROYING' to 'TERMINATED'
00:00:08.183862 Console: Machine state changed to 'PoweredOff'
00:00:08.690123 GUI: Passing request to close Runtime UI from machine-logic to UI session.
00:00:08.771047 GUI: UIMachineViewNormal::resendSizeHint: Restoring guest size-hint for screen 0 to 800x600
00:00:08.771092 ERROR [COM]: aRC=E_ACCESSDENIED (0x80070005) aIID={4680b2de-8690-11e9-b83d-5719e53cf1de} aComponent={DisplayWrap} aText={The console is not powered up (setVideoModeHint)}, preserve=false aResultDetail=0
00:00:08.771137 GUI: Aborting startup due to invalid machine state detected: 1
Let me know if you guys need more.
Here is the output I ran on my computer checking that virtualization was working.
[redac]-ThinkPad-E14-Gen-5:~$ kvm-ok
INFO: /dev/kvm exists
KVM acceleration can be used
[redac]-ThinkPad-E14-Gen-5:~$ lscpu | grep "Virtualization"
Virtualization: VT-x
Here are my system specs:
Any help would be appreciated. This has been a recurring problem that I would like to try to eliminate.
Also, I have had luck with different versions of VB on Zorin in the past. So maybe a dependency issue?
