VirtualBox vm's no longer have vm control menu at top of screen (ZorinOS 17)
I use VirtualBox vm's every day. They occasionally freeze. It is usually easy to un-freeze them by selecting 'Reset' from the 'Machine' menu located in the menu bar at the top of the vm window. I recently upgraded to Zorin OS 17 Pro. I believe I gained a newer version of VirtualBox with the OS upgrade. I cannot find any way to show this menu again. I do not know why it disappeared. I need to be able to reset rather than kill and restart the vm's. I looked through the 8 billion posts about VirtualBox to no avail. Thanks in advance.
Later that same day:
I have just discovered that some of my vm windows still show the menu, while others do not. They are all using the same version of VirtualBox. So it has to be a setting somewhere. I have repeatedly dug through all of the setting in the vm manager app as well as those of the vm itself.
Hi JimH Deldoy here I had the same with the last Zorin update you used to be able to get the menu by right clicking on the area where it should be and select show or hide but this also is not working.
I assume that you know that it is available in full screen and seamless modes you can switch this whilst running without problems
Hi it's Delboy again I was playing around with the problem and cured it on my PC what I did was to press Host+C let it change then press Host+C again up came the menu hope it works for you
Thanks, delboy. I'm not sure which key you mean by Host. I have a Win button. I tried Win+C, but nothing happened. I also tried going full screen, but the menu did not appear. I'm on Zorin OS 17 and VirtualBox says that it is 6.1.
Sorry have not been around to answer before now Host key is Right Control if you press right control +f you will go into full screen mode and provided you haven't altered the default settings the bar will appear if you hover the mouse at the bottom of the screen
You don't say what version you are working with you say 6.1.(what ) in the virtualbox [about virtualbox] at the bottom it will tell you I'm running 6.1.50
Thanks to you, I learned about the Host+Home shortcut to show a popup menu with the same sub-menus as the disappeared menu bar. That was the secret that I needed. The popup has a View sub-menu. I found an option to display the menu bar there. Problem solved. I still don't know why it disappeared in the first place, but I'll accept reality as it now presents.
Jim, can your last post #7 be marked as :ballot_box_with_check:Solution, if true?
Unfortunately, it is not resolved. I have searched and searched for a solution with no success. The menu is enabled in the vm settings. My 5 other regularly used vm's all have the menu showing. It is only one that does not. It hosts my web yahoo email on firefox. Replacing this vm would be a real pain given the loss of cookies. The current crop of captcha images is so blurred that I cannot succeed in passing the test.
OK, first off, backup all your crucial VM's to another location. Next, install virt-manager (Virtual Machine Manager). Always been superior in my eyes to Virtual Box, particularly with regard to USB 3.0 support, and the Desktops of VMs look more like a clean 'bare metal' install - but don't use for gaming!
virt-manager allows you to import VB vhd's and converts them into qcow2 images.
Thanks. I will try this and report back. However, I have been under the weather so it might be a little while before I get to it.
Ok. Now I am using Virtual Machine Manager. I'm having an issue. I receive a list of free or discounted books every day. When I see one that I want, I click on it and another window (Firefox) opens with a page for ordering the book from Amazon and other places. This worked with VirtualBox, but it does not work with Virtual Machine Manager. I checked the firewall rules and discovered that ufw was not enabled ... so that is not the issue. I looked through Firefox settings and could find nothing there that might explain it. I also looked through all of the preferences for the vm. Where else can I look? The second window is definitely being blocked. I think this is called a redirect. I could find no mention of redirects.
Have you tried different graphical settings in VM Details? Out of curiosity, what is the version of virt-manager installed? The current version is 4.1.0.
The version is 4.0.0. I installed it from a terminal with 'sudo apt install virt-manager. When I just tried to update it in the same way, it said that I already have the latest version. Where did you get 4.1.0?
Sorry to bother you. False alarm. When I tried to buy a book a new tab opened that remained blank. Turns out I needed to login to Amazon from the new vm. After I did that, it started working. An explanatory error message would have been great, but life is not perfect.
Thanks for your response.
I was wrong. For some reason, signing into Amazon so that I can receive books worked one time. Now, I'm logged in, but the the new tabs awaiting a response from Amazon just sit there with 'outgoing' showing as the name of the tab. However, if I restart the machine the response from Amazon shows.
Despite the stability issues I have with VirtualBox, I have returned to using it for now. This 'outgoing' problem is worse than the 'no menu bar' problem. The VirtualBox vm's do freeze fairly often when all I'm running in each of them is an instance of a Firefox browser. That's why the menu bar is so important. I can reset the vm using it. There is a key sequence that opens a popup menu with the same choices as the menu bar, but the sequence doesn't work when the vm is frozen.
