Here's a neat way to visualize the dependencies and reverse-dependencies for any given package.
First, you'll need to install apt-rdepends, a dependency and reverse-dependency parser:
sudo apt install apt-rdepends
And you'll need to install graphvis, a graph visualization package:
sudo apt install graphviz
Ok, so your packages are listed in /var/lib/dpkg/status. And you can get a list of your installed packages via sudo apt list --installed.
Let's take one of the packages at random... 'dash'.
We'd issue the following command to get the dependencies:
And in your /home directory, you'll find the file dependencies.png:
If you want to know the reverse-dependencies:
If you leave the image viewer open with that dependencies.png and type in a different package, the graphic will update.
