Who can help me ?
I have installed the VLC Player 3.0.11 Vetinari under Zorin Ultimate 15.3 and the stream “Renderer” to my internet-enabled television does not work. When “Renderer” is executed and I have selected my television in the network, the picture briefly turns black for a second and then switches back to the television picture.
Further information about PPA
The repository ‘http://ppa.launchpad.net/videolan/stable-daily/ubuntu bionic Release’ does not have a Release file.
Hi, robbi466.
How did you install VLC (source details)? That should also help us answer the repository question.
Zorin’s version is 3.08 which you can see under Synaptic. The package versions under Synaptic are the versions tested for stability on Zorin. That can be one of the reasons why you’re seeing problems with 3.0.11. Can you install the 3.08 (after completely removing 3.0.11) and then try and see if the Renderer function works?
