VMware Workstation - kcompacd0 using 100% CPU with VMware Workstation 16
Hi Experts,
I use VMware Workstation on my Zorin OS 16 Pro machine.
(Please don't suggest another hypervisor. I need the virtual TPM in VMware to run the vm for work. None of the other hypervisors will work.)
Is there a way to implement a fix in Zorin going forward for the following issue: kcompacd0 using 100% CPU with VMware Workstation 16 - Unix & Linux Stack Exchange
Additional Notes
This is the solution for me on Zorin 16 Pro:
Shut down the VM
Open the <vm_name>.vmx file for the VM using a text editor
Add the following lines to the end of the vmx file:
# Fix problem where vmware battles with kcompactd0.
vm.compaction_proactiveness=0
Save file and restart VM
If you upgrade to VMware Workstation Pro 16.2.1, make sure you upgrade your VMs to 16.2 and reboot your machine before testing. I did not reboot after upgrading and the issue persisted until the reboot.
Another user posted: From this link - Fixing khugepaged CPU usage VMware Workstation · GitHub - I found that editing /etc/sysctl.conf (different on Arch-based, but the same principle) worked for me:
---End of notes---
My System:
Kernel: 5.13.0-39-generic x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/vmlinuz-5.13.0-39-generic
root=/dev/mapper/vgzorin-root ro quiet splash vt.handoff=7
Desktop: Gnome 3.38.4 wm: gnome-shell dm: GDM3 3.38.2.1
Distro: Zorin OS 16.1 base: Ubuntu 20.04 LTS Focal
