VMware workstation not running after system update (Zorin 17.1)
Hi there -
I am on Zorin 17.1 - running on Lenovo AOI PC - everything quite nice.
The last native Windows programs I have in a VM on the (now) free VMware Worstation - after the Zorin update it wants to compile some things, but always fails. Fortunately I have Timeshift, so I can identify the update as the source of the error.
"Unable to install all modules ..... exit code 1" -
Did anyone else have the same problem?
Thanks!
Log:
024-08-15T15:39:29.874Z In(05) host-3605 Log for VMware Workstation pid=3605 version=17.5.2 build=build-23775571 option=Release
2024-08-15T15:39:29.874Z In(05) host-3605 The host is x86_64.
2024-08-15T15:39:29.874Z In(05) host-3605 Host codepage=UTF-8 encoding=UTF-8
2024-08-15T15:39:29.874Z In(05) host-3605 Host is Linux 6.8.0-40-generic Zorin OS 17.1 Zorin OS 17 17.1
2024-08-15T15:39:29.874Z In(05) host-3605 Host offset from UTC is +02:00.
2024-08-15T15:39:29.873Z In(05) host-3605 DictionaryLoad: Cannot open file "/usr/lib/vmware/settings": Datei oder Verzeichnis nicht gefunden.
2024-08-15T15:39:29.873Z In(05) host-3605 [msg.dictionary.load.openFailed] Cannot open file "/usr/lib/vmware/settings": Datei oder Verzeichnis nicht gefunden.
2024-08-15T15:39:29.873Z In(05) host-3605 PREF Optional preferences file not found at /usr/lib/vmware/settings. Using default values.
2024-08-15T15:39:29.873Z In(05) host-3605 DictionaryLoad: Cannot open file "/home/gt-rider/.vmware/config": Datei oder Verzeichnis nicht gefunden.
2024-08-15T15:39:29.873Z In(05) host-3605 [msg.dictionary.load.openFailed] Cannot open file "/home/gt-rider/.vmware/config": Datei oder Verzeichnis nicht gefunden.
2024-08-15T15:39:29.873Z In(05) host-3605 PREF Optional preferences file not found at /home/gt-rider/.vmware/config. Using default values.
2024-08-15T15:39:29.996Z Wa(03) host-3605 Logging to /tmp/vmware-gt-rider/vmware-3605.log
2024-08-15T15:39:30.029Z In(05) host-3605 Obtaining info using the running kernel.
2024-08-15T15:39:30.029Z In(05) host-3605 Created new pathsHash.
2024-08-15T15:39:30.029Z In(05) host-3605 Setting header path for 6.8.0-40-generic to "/lib/modules/6.8.0-40-generic/build/include".
2024-08-15T15:39:30.029Z In(05) host-3605 Validating path "/lib/modules/6.8.0-40-generic/build/include" for kernel release "6.8.0-40-generic".
2024-08-15T15:39:30.032Z In(05) host-3605 Failed to find /lib/modules/6.8.0-40-generic/build/include/linux/version.h
2024-08-15T15:39:30.032Z In(05) host-3605 /lib/modules/6.8.0-40-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2024-08-15T15:39:30.033Z In(05) host-3605 using /usr/bin/gcc-12 for preprocess check
2024-08-15T15:39:30.104Z In(05) host-3605 Preprocessed UTS_RELEASE, got value "6.8.0-40-generic".
2024-08-15T15:39:30.104Z In(05) host-3605 The header path "/lib/modules/6.8.0-40-generic/build/include" for the kernel "6.8.0-40-generic" is valid. Whoohoo!
2024-08-15T15:39:30.480Z In(05) host-3605 found symbol version file /lib/modules/6.8.0-40-generic/build/Module.symvers
2024-08-15T15:39:30.480Z In(05) host-3605 Reading symbol versions from /lib/modules/6.8.0-40-generic/build/Module.symvers.
2024-08-15T15:39:30.512Z In(05) host-3605 Read 28974 symbol versions
2024-08-15T15:39:30.513Z In(05) host-3605 Reading in info for the vmmon module.
2024-08-15T15:39:30.513Z In(05) host-3605 Reading in info for the vmnet module.
2024-08-15T15:39:30.513Z In(05) host-3605 Invoking modinfo on "vmmon".
2024-08-15T15:39:30.516Z In(05) host-3605 "/sbin/modinfo" exited with status 256.
2024-08-15T15:39:30.516Z In(05) host-3605 Invoking modinfo on "vmnet".
2024-08-15T15:39:30.520Z In(05) host-3605 "/sbin/modinfo" exited with status 256.
2024-08-15T15:39:30.542Z In(05) host-3605 to be installed: vmmon status: 0
2024-08-15T15:39:30.542Z In(05) host-3605 to be installed: vmnet status: 0
2024-08-15T15:39:30.583Z In(05) host-3605 Obtaining info using the running kernel.
2024-08-15T15:39:30.583Z In(05) host-3605 Setting header path for 6.8.0-40-generic to "/lib/modules/6.8.0-40-generic/build/include".
2024-08-15T15:39:30.583Z In(05) host-3605 Validating path "/lib/modules/6.8.0-40-generic/build/include" for kernel release "6.8.0-40-generic".
2024-08-15T15:39:30.583Z In(05) host-3605 Failed to find /lib/modules/6.8.0-40-generic/build/include/linux/version.h
2024-08-15T15:39:30.583Z In(05) host-3605 /lib/modules/6.8.0-40-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2024-08-15T15:39:30.583Z In(05) host-3605 using /usr/bin/gcc-12 for preprocess check
2024-08-15T15:39:30.593Z In(05) host-3605 Preprocessed UTS_RELEASE, got value "6.8.0-40-generic".
2024-08-15T15:39:30.593Z In(05) host-3605 The header path "/lib/modules/6.8.0-40-generic/build/include" for the kernel "6.8.0-40-generic" is valid. Whoohoo!
2024-08-15T15:39:30.954Z In(05) host-3605 found symbol version file /lib/modules/6.8.0-40-generic/build/Module.symvers
2024-08-15T15:39:30.954Z In(05) host-3605 Reading symbol versions from /lib/modules/6.8.0-40-generic/build/Module.symvers.
2024-08-15T15:39:30.982Z In(05) host-3605 Read 28974 symbol versions
2024-08-15T15:39:30.987Z In(05) host-3605 Kernel header path retrieved from FileEntry: /lib/modules/6.8.0-40-generic/build/include
2024-08-15T15:39:30.987Z In(05) host-3605 Update kernel header path to /lib/modules/6.8.0-40-generic/build/include
2024-08-15T15:39:30.987Z In(05) host-3605 Validating path "/lib/modules/6.8.0-40-generic/build/include" for kernel release "6.8.0-40-generic".
2024-08-15T15:39:30.987Z In(05) host-3605 Failed to find /lib/modules/6.8.0-40-generic/build/include/linux/version.h
2024-08-15T15:39:30.987Z In(05) host-3605 /lib/modules/6.8.0-40-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2024-08-15T15:39:30.987Z In(05) host-3605 using /usr/bin/gcc-12 for preprocess check
2024-08-15T15:39:30.997Z In(05) host-3605 Preprocessed UTS_RELEASE, got value "6.8.0-40-generic".
2024-08-15T15:39:30.997Z In(05) host-3605 The header path "/lib/modules/6.8.0-40-generic/build/include" for the kernel "6.8.0-40-generic" is valid. Whoohoo!
2024-08-15T15:39:30.998Z In(05) host-3605 Found compiler at "/usr/bin/gcc"
2024-08-15T15:39:31.004Z In(05) host-3605 Got gcc version "11".
2024-08-15T15:39:31.004Z In(05) host-3605 GCC major version 11 does not match Kernel GCC major version 12.
2024-08-15T15:39:31.004Z In(05) host-3605 Attempting to use a compiler at location "/usr/bin/gcc-12".
2024-08-15T15:39:31.006Z In(05) host-3605 Got gcc version "12".
2024-08-15T15:39:31.006Z In(05) host-3605 The GCC version matches the kernel GCC minor version like a glove.
2024-08-15T15:39:31.008Z In(05) host-3605 Got gcc version "12".
2024-08-15T15:39:31.008Z In(05) host-3605 The GCC version matches the kernel GCC minor version like a glove.
2024-08-15T15:39:31.011Z In(05) host-3605 Trying to find a suitable PBM set for kernel "6.8.0-40-generic".
2024-08-15T15:39:31.011Z In(05) host-3605 No matching PBM set was found for kernel "6.8.0-40-generic".
2024-08-15T15:39:31.011Z In(05) host-3605 The GCC version matches the kernel GCC minor version like a glove.
2024-08-15T15:39:31.011Z In(05) host-3605 Validating path "/lib/modules/6.8.0-40-generic/build/include" for kernel release "6.8.0-40-generic".
2024-08-15T15:39:31.011Z In(05) host-3605 Failed to find /lib/modules/6.8.0-40-generic/build/include/linux/version.h
2024-08-15T15:39:31.011Z In(05) host-3605 /lib/modules/6.8.0-40-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2024-08-15T15:39:31.011Z In(05) host-3605 using /usr/bin/gcc-12 for preprocess check
2024-08-15T15:39:31.020Z In(05) host-3605 Preprocessed UTS_RELEASE, got value "6.8.0-40-generic".
2024-08-15T15:39:31.020Z In(05) host-3605 The header path "/lib/modules/6.8.0-40-generic/build/include" for the kernel "6.8.0-40-generic" is valid. Whoohoo!
2024-08-15T15:39:36.745Z In(05) host-3605 The GCC version matches the kernel GCC minor version like a glove.
2024-08-15T15:39:36.745Z In(05) host-3605 Validating path "/lib/modules/6.8.0-40-generic/build/include" for kernel release "6.8.0-40-generic".
2024-08-15T15:39:36.745Z In(05) host-3605 Failed to find /lib/modules/6.8.0-40-generic/build/include/linux/version.h
2024-08-15T15:39:36.745Z In(05) host-3605 /lib/modules/6.8.0-40-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2024-08-15T15:39:36.745Z In(05) host-3605 using /usr/bin/gcc-12 for preprocess check
2024-08-15T15:39:36.757Z In(05) host-3605 Preprocessed UTS_RELEASE, got value "6.8.0-40-generic".
2024-08-15T15:39:36.757Z In(05) host-3605 The header path "/lib/modules/6.8.0-40-generic/build/include" for the kernel "6.8.0-40-generic" is valid. Whoohoo!
2024-08-15T15:39:36.757Z In(05) host-3605 Using temp dir "/tmp".
2024-08-15T15:39:52.682Z In(05) host-3605 Stopping VMware services:
2024-08-15T15:39:52.682Z In(05) host-3605 VMware Authentication Daemone[71G done
2024-08-15T15:39:52.682Z In(05) host-3605 Virtual machine monitore[71G done
2024-08-15T15:39:52.682Z In(05) host-3605 make: Verzeichnis „/tmp/modconfig-ydJcbS/vmmon-only“ wird betreten
2024-08-15T15:39:52.682Z In(05) host-3605 /usr/bin/make -C /lib/modules/6.8.0-40-generic/build/include/.. M=$PWD SRCROOT=$PWD/.
2024-08-15T15:39:52.682Z In(05) host-3605 MODULEBUILDDIR= modules
2024-08-15T15:39:52.682Z In(05) host-3605 make[1]: Verzeichnis „/usr/src/linux-headers-6.8.0-40-generic“ wird betreten
2024-08-15T15:39:52.682Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmmon-only/linux/driver.o
2024-08-15T15:39:52.682Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmmon-only/linux/driverLog.o
2024-08-15T15:39:52.682Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmmon-only/linux/hostif.o
2024-08-15T15:39:52.682Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmmon-only/common/apic.o
2024-08-15T15:39:52.683Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmmon-only/common/comport.o
2024-08-15T15:39:52.683Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmmon-only/common/cpuid.o
2024-08-15T15:39:52.683Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmmon-only/common/crosspage.o
2024-08-15T15:39:52.683Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmmon-only/common/memtrack.o
2024-08-15T15:39:52.683Z In(05) host-3605 make[1]: Verzeichnis „/usr/src/linux-headers-6.8.0-40-generic“ wird verlassen
2024-08-15T15:39:52.683Z In(05) host-3605 make: Verzeichnis „/tmp/modconfig-ydJcbS/vmmon-only“ wird verlassen
2024-08-15T15:39:52.683Z In(05) host-3605 make: Verzeichnis „/tmp/modconfig-ydJcbS/vmnet-only“ wird betreten
2024-08-15T15:39:52.683Z In(05) host-3605 /usr/bin/make -C /lib/modules/6.8.0-40-generic/build/include/.. M=$PWD SRCROOT=$PWD/.
2024-08-15T15:39:52.683Z In(05) host-3605 MODULEBUILDDIR= modules
2024-08-15T15:39:52.683Z In(05) host-3605 make[1]: Verzeichnis „/usr/src/linux-headers-6.8.0-40-generic“ wird betreten
2024-08-15T15:39:52.683Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmnet-only/driver.o
2024-08-15T15:39:52.683Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmnet-only/hub.o
2024-08-15T15:39:52.683Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmnet-only/userif.o
2024-08-15T15:39:52.683Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmnet-only/netif.o
2024-08-15T15:39:52.683Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmnet-only/bridge.o
2024-08-15T15:39:52.683Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmnet-only/procfs.o
2024-08-15T15:39:52.683Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmnet-only/smac_compat.o
2024-08-15T15:39:52.683Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmnet-only/smac.o
2024-08-15T15:39:52.683Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmnet-only/vnetEvent.o
2024-08-15T15:39:52.683Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmnet-only/vnetUserListener.o
2024-08-15T15:39:52.683Z In(05) host-3605 LD [M] /tmp/modconfig-ydJcbS/vmnet-only/vmnet.o
2024-08-15T15:39:52.683Z In(05) host-3605 MODPOST /tmp/modconfig-ydJcbS/vmnet-only/Module.symvers
2024-08-15T15:39:52.683Z In(05) host-3605 CC [M] /tmp/modconfig-ydJcbS/vmnet-only/vmnet.mod.o
2024-08-15T15:39:52.683Z In(05) host-3605 LD [M] /tmp/modconfig-ydJcbS/vmnet-only/vmnet.ko
2024-08-15T15:39:52.683Z In(05) host-3605 BTF [M] /tmp/modconfig-ydJcbS/vmnet-only/vmnet.ko
2024-08-15T15:39:52.683Z In(05) host-3605 /usr/bin/make -C $PWD SRCROOT=$PWD/.
2024-08-15T15:39:52.683Z In(05) host-3605 MODULEBUILDDIR= postbuild
2024-08-15T15:39:52.683Z In(05) host-3605 make[1]: Verzeichnis „/tmp/modconfig-ydJcbS/vmnet-only“ wird betreten
2024-08-15T15:39:52.683Z In(05) host-3605 make[1]: „postbuild“ ist bereits aktuell.
2024-08-15T15:39:52.683Z In(05) host-3605 make[1]: Verzeichnis „/tmp/modconfig-ydJcbS/vmnet-only“ wird verlassen
2024-08-15T15:39:52.683Z In(05) host-3605 cp -f vmnet.ko ./../vmnet.o
2024-08-15T15:39:52.683Z In(05) host-3605 make: Verzeichnis „/tmp/modconfig-ydJcbS/vmnet-only“ wird verlassen
2024-08-15T15:39:52.683Z In(05) host-3605 [AppLoader] Use shipped Linux kernel AIO access library.
2024-08-15T15:39:52.683Z In(05) host-3605 An up-to-date "libaio" or "libaio1" package from your system is preferred.
2024-08-15T15:39:52.683Z In(05) host-3605 [AppLoader] GLib does not have GSettings support.
2024-08-15T15:39:52.683Z In(05) host-3605 Using kernel build system.
2024-08-15T15:39:52.683Z In(05) host-3605 warning: the compiler differs from the one used to build the kernel
2024-08-15T15:39:52.683Z In(05) host-3605 The kernel was built by: x86_64-linux-gnu-gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
2024-08-15T15:39:52.683Z In(05) host-3605 You are using: gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
2024-08-15T15:39:52.683Z In(05) host-3605 /tmp/modconfig-ydJcbS/vmmon-only/common/crosspage.o: warning: objtool: CrossPage_CodePage+0x207: 'naked' return found in RETHUNK build
2024-08-15T15:39:52.683Z In(05) host-3605 make[3]: *** [scripts/Makefile.build:243: /tmp/modconfig-ydJcbS/vmmon-only/common/crosspage.o] Fehler 255
2024-08-15T15:39:52.683Z In(05) host-3605 make[3]: *** Datei „/tmp/modconfig-ydJcbS/vmmon-only/common/crosspage.o“ wird gelöscht
2024-08-15T15:39:52.683Z In(05) host-3605 make[3]: *** Auf noch nicht beendete Prozesse wird gewartet …
2024-08-15T15:39:52.683Z In(05) host-3605 /tmp/modconfig-ydJcbS/vmmon-only/linux/hostif.c:2926:1: warning: no previous prototype for ‘HostIFCheckTrackedMPN’ [-Wmissing-prototypes]
2024-08-15T15:39:52.683Z In(05) host-3605 2926 | HostIFCheckTrackedMPN(VMDriver *vm, // IN: The VM instance
2024-08-15T15:39:52.683Z In(05) host-3605 | ^~~~~~~~~~~~~~~~~~~~~
2024-08-15T15:39:52.683Z In(05) host-3605 /tmp/modconfig-ydJcbS/vmmon-only/linux/hostif.c:3046:1: warning: no previous prototype for ‘HostIFWritePhysicalWork’ [-Wmissing-prototypes]
2024-08-15T15:39:52.683Z In(05) host-3605 3046 | HostIFWritePhysicalWork(MA ma, // MA to be written to
2024-08-15T15:39:52.683Z In(05) host-3605 | ^~~~~~~~~~~~~~~~~~~~~~~
2024-08-15T15:39:52.683Z In(05) host-3605 /tmp/modconfig-ydJcbS/vmmon-only/linux/hostif.c:3205:1: warning: no previous prototype for ‘HostIFStartTimer’ [-Wmissing-prototypes]
2024-08-15T15:39:52.683Z In(05) host-3605 3205 | HostIFStartTimer(Bool rateChanged, //IN: Did rate change?
2024-08-15T15:39:52.683Z In(05) host-3605 /tmp/modconfig-ydJcbS/vmmon-only/linux/driver.c:271:1: warning: no previous prototype for ‘LinuxDriverInit’ [-Wmissing-prototypes]
2024-08-15T15:39:52.683Z In(05) host-3605 271 | LinuxDriverInit(void)
2024-08-15T15:39:52.683Z In(05) host-3605 /tmp/modconfig-ydJcbS/vmmon-only/linux/driver.c:339:1: warning: no previous prototype for ‘LinuxDriverExit’ [-Wmissing-prototypes]
2024-08-15T15:39:52.683Z In(05) host-3605 339 | LinuxDriverExit(void)
2024-08-15T15:39:52.683Z In(05) host-3605 make[2]: *** [/usr/src/linux-headers-6.8.0-40-generic/Makefile:1926: /tmp/modconfig-ydJcbS/vmmon-only] Fehler 2
2024-08-15T15:39:52.683Z In(05) host-3605 make[1]: *** [Makefile:240: __sub-make] Fehler 2
2024-08-15T15:39:52.683Z In(05) host-3605 make: *** [Makefile:117: vmmon.ko] Fehler 2
2024-08-15T15:39:52.683Z In(05) host-3605 /tmp/modconfig-ydJcbS/vmnet-only/userif.c:1091:1: warning: no previous prototype for ‘VNetUserIf_Create’ [-Wmissing-prototypes]
2024-08-15T15:39:52.683Z In(05) host-3605 1091 | VNetUserIf_Create(VNetPort **ret) // OUT
2024-08-15T15:39:52.683Z In(05) host-3605 /tmp/modconfig-ydJcbS/vmnet-only/netif.c:173:1: warning: no previous prototype for ‘VNetNetIf_Create’ [-Wmissing-prototypes]
2024-08-15T15:39:52.683Z In(05) host-3605 173 | VNetNetIf_Create(char *devName, // IN:
2024-08-15T15:39:52.683Z In(05) host-3605 /tmp/modconfig-ydJcbS/vmnet-only/userif.o: warning: objtool: VNetCsumAndCopyToUser+0x2d: call to csum_partial_copy_nocheck() with UACCESS enabled
2024-08-15T15:39:52.683Z In(05) host-3605 /tmp/modconfig-ydJcbS/vmnet-only/bridge.c:258:1: warning: no previous prototype for ‘VNetBridge_Create’ [-Wmissing-prototypes]
2024-08-15T15:39:52.683Z In(05) host-3605 258 | VNetBridge_Create(const char *devName, // IN: name of device (e.g., "eth0")
2024-08-15T15:39:52.683Z In(05) host-3605 /tmp/modconfig-ydJcbS/vmnet-only/bridge.c:1411:1: warning: no previous prototype for ‘VNetBridgeSendLargePacket’ [-Wmissing-prototypes]
2024-08-15T15:39:52.683Z In(05) host-3605 1411 | VNetBridgeSendLargePacket(struct sk_buff *skb, // IN: packet to split
2024-08-15T15:39:52.683Z In(05) host-3605 | ^~~~~~~~~~~~~~~~~~~~~~~~~
2024-08-15T15:39:52.683Z In(05) host-3605 /tmp/modconfig-ydJcbS/vmnet-only/vnetUserListener.c:87:1: warning: no previous prototype for ‘VNetUserListener_Create’ [-Wmissing-prototypes]
2024-08-15T15:39:52.683Z In(05) host-3605 87 | VNetUserListener_Create(uint32 classMask, // IN: the listener's class mask
2024-08-15T15:39:52.683Z In(05) host-3605 Skipping BTF generation for /tmp/modconfig-ydJcbS/vmnet-only/vmnet.ko due to unavailability of vmlinux
2024-08-15T15:39:52.683Z In(05) host-3605 Unable to install all modules. See log for details.
It looks like this has been an issue with this particular version of the Linux kernel. Checkout this thread, some people have reportedly found a workaround this issue; hopefully it can help:
Thank you for the hint - most of the workarounds did not work, but the very last one in the thread mentioned worked for me (for now - let's see, how many updates it lasts)...
git clone GitHub - mkubecek/vmware-host-modules: Patches needed to build VMware (Player and Workstation) host modules against recent kernels
cd vmware-host-modules
git switch workstation-17.5.1
make
sudo make install
(I had to run all commands with sudo)
