Voıce not working after sleep(snd_hda_intel driver)
I thınk this is a kernel issue because ı buy a new laptop and ı want to try arch based systems but my voice not working after sleep and I thınk thıs ıs arch based os ıssue and comeback zorınos but after that thıs ısnt workıng agaın ı tried zorin help page solıotıons and not workıng after that I learn my driver snd_hda_intel and thıs is causing bugs I don't know how to fiz it can you help me here is my inxi -Fxz commend (sorry for bad english not my first language)
System:
  Kernel: 6.5.0-45-generic x86_64 bits: 64 compiler: N/A Desktop: GNOME 43.9
    Distro: Zorin OS 17.1 base: Ubuntu 22.04 LTS Jammy
Machine:
  Type: Laptop System: CASPER BILGISAYAR SISTEMLERI product: NIRVANA NB C550
    v: ADL-P_EM_IDL8369_SUB2_CS550_V0.59.4 serial: <superuser required>
  Mobo: CASPER BILGISAYAR SISTEMLERI model: C550 001
    serial: <superuser required> UEFI: CASPER BILGISAYAR SISTEMLERI
    v: ADL-P_EM_IDL8369_SUB2_CS550_V0.59.4 date: 05/06/2023
Battery:
  ID-1: BAT0 charge: 36.5 Wh (80.0%) condition: 45.6/45.6 Wh (100.0%)
    volts: 11.4 min: N/A model: Intel SR 1 SR Real Battery status: Discharging
CPU:
  Info: 10-core (2-mt/8-st) model: 12th Gen Intel Core i5-1235U bits: 64
    type: MST AMCP arch: Alder Lake rev: 4 cache: L1: 928 KiB L2: 6.5 MiB
    L3: 12 MiB
  Speed (MHz): avg: 416 high: 602 min/max: 400/1300:900 cores: 1: 602
    2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400
    12: 400 bogomips: 59904
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
  Device-1: Intel vendor: nCipher Security driver: i915 v: kernel
    bus-ID: 00:02.0
  Device-2: Sunplus Innovation Camera type: USB driver: uvcvideo
    bus-ID: 1-5:2
  Display: wayland server: X.Org v: 1.22.1.1 with: Xwayland v: 22.1.1
    compositor: gnome-shell driver: gpu: i915 resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel Graphics (ADL GT2)
    v: 4.6 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
Audio:
  Device-1: Intel Alder Lake PCH-P High Definition Audio
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
  Sound Server-1: ALSA v: k6.5.0-45-generic running: yes
  Sound Server-2: PulseAudio v: 15.99.1 running: yes
  Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3
  IF: wlo1 state: up mac: <filter>
  Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
  IF: enp2s0 state: down mac: <filter>
Bluetooth:
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 1-10:4
  Report: hciconfig ID: hci0 rfk-id: 0 state: down
    bt-service: enabled,running rfk-block: hardware: no software: no
    address: <filter>
Drives:
  Local Storage: total: 465.76 GiB used: 29.97 GiB (6.4%)
  ID-1: /dev/nvme0n1 vendor: Crucial model: CT500P3PSSD8 size: 465.76 GiB
    temp: 31.9 C
Partition:
  ID-1: / size: 98.44 GiB used: 29.94 GiB (30.4%) fs: ext4
    dev: /dev/nvme0n1p5
  ID-2: /boot/efi size: 96 MiB used: 33 MiB (34.4%) fs: vfat
    dev: /dev/nvme0n1p1
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:
  System Temperatures: cpu: 40.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 310 Uptime: 12m Memory: 7.49 GiB used: 2.43 GiB (32.4%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 clang: 14.0.0-1ubuntu1.1
  Packages: 2562 Shell: Bash v: 5.1.16 inxi: 3.3.13
From websearch using "Intel Alder Lake PCH-P High Definition Audio no sound ubuntu 22.04"
I found this:
...which refers to bug reports.
Did you have any sound (e.g. from headphone) either when you had arch based distro, or Zorin (ubuntu 22.04 based distro). Asking, as a later kernel (6.9.0) may now contain a fix according to last comment here: 216311 – Add HP Envy x360 15 (Model: 15-ey0xxx, 8A31) to ALC245 codec fixes (snd_hda_id_realtek)
You may wish to do your own additional websearches using the search term I quoted above, to see if anything new comes up.
I did a short research and I think the problem is not in the kernel or the os. I think there is no full support for the alder lake you mentioned. My kernel has the latest update and a few people with the problem I mentioned solved the problem in 5.18. I think it was not solved only in alder lake. At first, everyone who mentioned this problem has the same driver. (snd_hda_intel) I thought the error was caused by this. I don't know, maybe I didn't make a correct setting in my BIOS, it looks like I'll switch to Windows for now, it works perfectly there, but thank you for your help.
Just to confirm, Linux detects the device (which means it can identify it but does not work). Just remember, the devices in your notebook were designed for that other OS, not Linux.
An alternative solution would be:
