In my Opinion, there is no need to put the name Line Out on the volume indicator… It should be minimalist like Windows 11.
I usually get rid of Pulse Audio anyway and use QAS mixer with ALSA instead. Far superior to pulse audio!
One advantage over Windows is you can put your mouse cursor on the speaker icon and scroll the volume up/down. No clicking needed.
But I use Input Remapper to make my side mouse buttons do volume up/down.
