Somebody teach me how to fix iostream no directory or something on VSCode pls
There are not any "Edit includePath..." so its so hard to do as the tutorial from Youtube
(I'm not good at English, sometimes using wrong grammar)
I hope this topic helpful!
How did you install VSCode?
If you used the APT repository, run:
sudo apt --fix-missing
sudo apt update && sudo apt install --reinstall code
I installed it from Zorin Store
ain't no way buddy
it's worked!
thank you so much!
