Witam. czy ktoś używa tej aplikacji na zorinie ???? mam to na platformie steam. i jestem ciekawy czy będę mógl z niej korzystac i tu
Wallpaper Engine is for Windows only and will not work on Linux.
On Linux, you can use Variety
wallpaper changer:
sudo apt install variety
The direct repo may have newer version:
sudo add-apt-repository ppa:variety/stable
Thank you! I just installed Zorin OS last night, and so far my only "disappointment" was that there was there wasn't a background/wallpaper changer built in. Not only did this work perfectly, but Variety is an even better wallpaper changer than I was hoping for.
