I’d like to share a step-by-step guide to install Waydroid on Zorin OS 18, so you can run Android apps natively on your Linux desktop. This method works best on Wayland sessions, as Waydroid integrates smoothly without requiring Weston.
Step 1: Make sure you have Zorin OS 18 with Wayland as Default Compositor. Its there in Zorin OS 18 as default.
Step 2: Download Android System.img and Vendor.img from Sourceforge from this link.
Step 3: Extract the Android System and Vendor Images with Unzip command.
Hi, there was a game that used to be on PC that is now only on Android. I have played around with that other OS and its Android Virtual Software but it did not work as the exported package became .apk+. Is it just a case of using File Roller to extract from .apk+? The game in question is Shadow Fight 2.
@techsolutionz,
I have removed the video links in your post.
A moderator removed your previous thread and sent you a Private Message explaining the Zorin Forum's Guidelines and Terms Of Service.
Bypassing the actions of a moderator and recreating removed post or threads can result in suspension or ban.
Unsolicited Self Promotion is against the Terms of Service.
That being said: Helpful content, guides and walkthroughs are able to benefit the users of GnuLinux as a whole. You are tightrope walking somewhere in between.
To this end: I am opening a dialog that you are part of - including the ZorinGroup and Moderator team where you can present your case.
(I initially closed this thread, but as @swarfendor437 has asked you a question on topic, reopened it so you may reply.)
