WebApps GUI Broken, can i help?
Hi,
I noticed the webapps gui is broken, the StartupWMClass=your-app-name seems not to work properly causing all apps in the dock to appear under the specific web browser. As apposed to getting their own icon in the dock.
I'm wondering if there is a repo i could make a PR and fix this issue or if i made my own WebApp GUI specifically for Zorin OS would that be alright?
Let me know what you think!
Thank you for the awesome distro and all your hard work!
If you'd like to create that, go ahead!
Or you can take a look at this thread:
Is the Browser installed as Flatpak or .deb/APT Version? You could also try it with reinstalling the WebApps Program with sudo apt reinstall webapp-manager
Yeah thank you!! This is exactly the guide I’ve been following to fix it in the mean time but figured a PR or new app catered to Zorin beginner users might be something.
I’ll take a stave at it this month and share it here :blush:
Thank you for the reply!
Unfortunately this didn’t fix my issues, the guide above mentioned did help but the process is manual and honestly not as fun to set up for all the apps.
You could try a different WebApp Program to check if the runs better. When You search in Gnome Software, You can find some:
