So I all the suden experiance a blinking gear icon on my task bar.
No reason or explanationt
Just a blinling item
It would be easy to help you if we see what you see...
I have to reboot to fix this
Never ever experiance this on mint
OK but we can't help you if we don't see your problem !
To be fare I am a new user as mosy are. And this type of sytuff makes me lean more towards mint
to be fare do what you want but if you don't give us something to help you, sure it will not be fix...
I have both
Mint on laptop and Zorin on desk top. I can say that miny has been more pleasent
OK so you don't need help, good luck with mint...
Thank
you
To many loop holes and needless encounters
mint just works I dont even need to use forum
Dont get me wrong I like tinkering. But this is my concensus
I want to like Zorin. But its getting hard..
I may actually switch my desk-top to Mint
50$ pitch i dont care less about, but the OS i do
Basicly said as a pc builder/user Mint has been a more pleasant exp.
That said I do more stuff on my desktop. but ya
I am intrested in why I have this issue. But in the end, I would rather just not have the issue in the fisrt place.
my guess is that pakage magager is f up
