Not sure what happened - was doing some cleanup with my Wine apps that didn't turn out too well.
Rebooted - all my /home contents were on my desktop .. weird.
I did not edit /home/me/.config/user-dirs.dirs
file, but it did something weird to the Desktop location - it was just /HOME
and that was it
Not had that one before!
But - I did get it fixed, relatively easy:
Create a new directory in /home called 'Desktop' - edit user-dirs.dirs where it says XDG_DESKTOP_DIR="$HOME"
to XDG_DESKTOP_DIR="$HOME/Desktop"
- Save that file, make sure it saves - then reboot..
All should be back to normal!
If not - check to make sure the file saved, and try once more
Just wanted to toss that one out there - have never experienced that one before. I can see through searching that it's happened before; just not too sure if I should call it a 'bug' or not..
