$ sudo apt wget -qO- https://www.postgresql.org/media/keys/ACCC4CF8.asc | sudo tee /etc/apt/trusted.gpg.d/pgdg.asc &>/dev/null
$: command not found
What command is not found?
You copied the leading dollar symbol $
which is not a valid command. Remove it and make sure it's just:
sudo apt wget -qO- https://www.postgresql.org/media/keys/ACCC4CF8.asc 1 | sudo tee /etc/apt/trusted.gpg.d/pgdg.asc &>/dev/null
It should be sudo wget
in your command.
You included two software commands: apt
and wget.
It seems I'm overly sloppy today, I didn't notice that there were two commands there in a row... oops
oops! Thank you guys.
