What is Optimal hardware configuration for Zorin?
Hello. I just discovered Zorin and would like to try it out on a dedicated PC. My goal is to not spend a fortune on a bleeding edge PC, so I am thinking of getting an i5 PC with either 8 or 16GB RAM and a 250(ish)GB SSD.
Its use is mostly for productivity, so I am not looking for a killer graphics system. Where I have doubts is about the RAM capacity and CPU generation. I am leaning towards 16GB, but will I see a boost in performance compared to an 8GB RAM system?
i5s, and other Intel CPUs come in plethora of generations, the newest being the 14th, (aside from the Ultra Core). For the sake of saving money, my idea is to buy an older generation, but I don't want to buy a PC that is so old that will cause Zorin to run sluggishly. I see some old i5s (6th, 7th gen) selling for $75 - $80 (USD), but I am willing to spend more if it means better performance. Which gen processor is best to get started without breaking the bank?
Any orientation is welcomed! Thank you! Saga
Most of the time, not really. Having more RAM really matters if you are consistently running heavy resources back to back or... if you are one of those people that keeps 100 tabs open in a browser.
Going with 16 gigs would be more for future proofing and comfort, since you are not gaming or doing heavy graphical work.
You would see slightly better performance on the later generations. But that is not why I would recommend them...
I recommend the later generations because of improvements in efficiency and power use. If this is a notebook computer, that matters a lot.
On Windows OS, due to OS bloat, you would struggle with an older gen CPU. On Zorin OS of most GnuLinux, you would barely notice the difference in just average daily web browsing.
You would notice it a bit if doing heavier tasks. Apps launching a bit more quickly, better loading times on development tools or graphics stacks. Things like that.
A 250gig SSD is perfectly fine for a non-gamer, non-heavy development task machine.
SSD is quicker than HDD (Noticeably) and my recommendation is a bare minimum of 64 gigs for the O.S. installation. If a person needs greater storage, they can add a dedicated storage drive later.
I would probably try to get 9th or 10th gen or higher, you're not spending much for them anymore and compared to even older gens, the cost difference is very minimal. As aravisian said, I would go with the 16 gigs of ram over 8 just for safety's sake, but you could add more later if you're planning on building a pc and are really strapped for cash right now.
Thank you! This clears up a lot of doubts that I had. Saga
Thank you! Mentioning the gen numbers helped a lot! Saga
The 16 Gig's of RAM would be a good Idea - especially when You use an internal Graphics because it takes their RAM from the common RAM.
Only to throw some Hardware Suggestions:
  • CPU: Ryzen 3200G or 3400G
  • Mainboard: Gigabyte A520i AC itx
  • RAM: 16 GB G.Skill Aegis 2x8GB 3200Mhz
  • Drive: Lexar NM620 256GB nvme m.2
4GB is sufficient, 8GB won't be fully used, 16GB is considered standard, because retailers have to justify the 202 5-price levels and Windows 11 requires 6GB as the (practical) minimum, which is not the practical minimum for Zorin or other distros.
Series Zorin Education (8GB) Zorin Core (+8GB) Zorin Pro (+16GB)
Apple M Apple M3 Pro
16th Gen (2025) Core Ultra 205 Core Ultra 225
14th Gen (2023/24) Core i_ 14100 Core i_ 14400
12th Gen Core i_ 12100 Core i_ 12600 12600KF
10th Gen Core i_ 10700 Core i_ 10900
AM5 (2024/25) Ryzen 9600X
AM5 Ryzen 8700F
AM5 Ryzen 7700
AM4 Ryzen 5600G Ryzen 5500X3D
AM4 Ryzen 5500
AM4 Ryzen 3600
The newest generation in Intel is not the Core i_ 14000, but Core Ultra 200, it's the 16th generation. The lowest is the Intel Core Ultra 205, released only lately and only in some conutries, South Korea to be exact. It's on the level of Core i_ 12600 and 10900.
The next higher (or second lowest) is the Core Ultra 225. It's equivalent to the Core i_ 14400 and 12600KF, Ryzen 7700, Ryzen 8700F and Ryzen 9600X.
Going further up would be ridiculous, because these are CPU speeds considered recommended and fully sufficient for the latest blockbuster 3D action shooters, like Battlefield 6, Cyperpunk 2077. We're talking about CPU speeds that Apple calls M3 Pro, where Pro is mostly an indicator to professional graphic designers and video editing (Adobe Premiere Pro) etc.
Typical office laptops are way slower, the standard office laptop speeds are comparable to these desktop CPUs: 10700, 12100, 14100, Ryzen 3600. The Ryzen 7000, 8000, and 9000 don't have any desktop model for that anymore. I'd say, the probably best low-level desktop CPU, which is still faster than the here mentioned, is the Ryzen 5500 (AM4 socket), it's fast, standard office speed, and has a very low energy consumption during idle. (If you were to pair the Ryzen 5500 with a [not really fancy] Radeon 7600, you could comfortably play the blockbuster titles at medium settings.) The Ryzen 5500 is said to get a re-release, Ryzen 5500X3D, for Latin America due to its suitable desktop speed and low energy consumption. You probably want the 5600G, because it has an integrated graphics card, so you don't need a separate graphics card.
For Intel, you always have a graphics unit in the CPU, unless the CPU name has the F, e.g. 12600KF. For AMD, you need to check https://computercity.com/hardware/processors/list-of-amd-ryzen-processors-with-integrated-graphics for the integrated graphics unit, usually the name has G, but many names don't tell.
RAM:
8GB of RAM is no longer sufficient to power the OS + APPS in 2025 modern installations. Making sure to have at least "16GB" of RAM is indicated. If you do heavy gaming, or production workloads, "32GB" of RAM is recommended. Heavy VM usage, "64GB" to "128GB" of RAM.
Storage:
250GB is also no longer relevant, due to OS's + updates, APPS, and games, requiring much more space. If your not a gamer, nor do production workloads, 512GB should be sufficient. If you are a gamer and or do production workloads, its typically recommended to have 1TB minimum, up to 4TB recommended.
I see now here you indicate, it will be used for production usage. In regards to performance, I would strongly recommend the usage of a Core I7 CPU with 8-cores, 16-threads minimum. I would also recommend an Nvidia GPU, no older then the 30 series generation, with at least 16GB of VRAM minimum.
You will see a huge boost in performance! 8GB will make your system craw and hit SWAP filing so much, till it destroys your storage drive. You really need to be thinking about 16GB as your minimum in 2025. And like I said, with heavy production workloads, especially in the 4K variety, step up to 32GB recommended RAM.
Please note, Core I5's are not meant for gaming/production workloads, they are general usage CPU's. Gaming/production should be done on Core I7 CPU's, heavy production (think 8K) should be done on Core I9 CPU's.
If your purpose is to not break the bank, you will have to go with a full AMD system. I don't use AMD systems, so you will need specific advice from someone else who has the advanced knowledge on them in modern day.
I think now is the best opportunity to get hold of cheap, still perfectly usable hardware. If you don't need the latest and only want to install Linux and not Windows 11, you could buy a computer with a 7th generation Intel. As these are no longer win 11 capable, these machines are available very cheaply. It depends on what you want to do with your system. 8 GB should be the minimum, with 16 or more it runs more smoothly. However, I would not buy a device with a fixed 8 GB RAM that cannot be increased.
It depends on your budget and what you want to do with your computer, which operating system you want to run on it and how long you want to use it in the future.
If you are looking for the cheapest possible device that will only run Linux and you are sure that you don't want to switch back to Windows with this machine, then you can go for one with the Intel 7th generation.
