As some of you know I have installed Zorin 16 Core as a dual boot with Windows 11.
I have setup VirtualBox with Windows 10 running really well with my Windows apps that I need that cant run on Zorin. I am ready to stop using my Windows 11 for a number of reasons.
- Some of my license Keys cant be used on two systems.
- Just complicates things unnecessarily.
- Simpler boot process.
- Trying to keep Win11 synced with my folders (like docs)on Zorin is time consuming and possible errors can occur.
I want remove the dual boot option and recover all the disk space used by the Win11 installation.
So any suggestion on what to do will be very helpful.
I will perform a full Macrium Reflect image backup of the C: Driveif needed to go back or even install on VirtualBox.
Thanks
Raymond
