Hello been Just re-installed dzorin after a while having an issue when I do SIngle Monitor it starts to slow the screendown
When I do Extend Screen the Monitor Shows a Black screen any helppwithj this?
With new install you WILL need a few update/upgrades.
Please tell us your pc spec''s.
desktop/laptop?
cpu size:
Ram:
ssd:
Psu:
Are you using ZorinOS core or Lite?
Is this dual boot or clean install?
To Update, ( with both monitor's plugged in)
Open " Software & Updates "
Goto " Additional Drivers" TAB,
If you see drivers listed select the one's that match your equipment .
Now Open " Software Updater"
run then start pc.
Can i ask you to change your profile so we can see the Zorin " Edition" you are using, saves us asking. ![]()
From @Derek 's other post
Maybe he can confirm it is the same machine.
