it just showing that when i enable bluetooth. please help me to fix these problem. it is not showing any device.
Can you please post the output of
sudo lshw -c network
*-network
product: RTL810xE PCI Express Fast Ethernet controller
physical id: 0
bus info: pci@0000:01:00.0
logical name: enp1s0
version: 05
serial: 00:e0:4c:6c:0d:a1
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.13.0-51-generic firmware=rtl_nic/rtl8105e-1.fw latency=0 link=no multicast=yes port=twisted pair
resources: irq:16 ioport:e800(size=256) memory:fdfff000-fdffffff memory:fdff8000-fdffbfff
Hmm... this should have bluetooth support (Radio driver) in the wifi driver.
Have you tried installing blueman
sudo apt install blueman
And launching blueman to adjust the bluetooth and try connecting to devices?
Thanks for reply. after installing blueman when i disable bluetooth this icon is showing but when i turn on/enable bluetooth it disappears and still showing "bluetooth truned off". what should i do next?
Let's try:
sudo rmmod btusb
sudo modprobe btusb
sudo systemctl enable Bluetooth
Just as you see it here with the asterisk too:
sudo apt install -y bluez*
OR
sudo apt install --reinstall bluez*
sudo systemctl enable bluetooth
sudo systemctl start bluetooth
when i run command
first time it is showing this and second time this
what should i do next.
Please see above where i posted during your Repost.
nothing happend after this command
Have you tested a Bluetooth device?
I am stumped.
The only thing I can wonder about now is... is it the Bluetooth device itself...
bluetooth device means problem in my bluetooth driver?
No, in the hardware.
in my bluetooth adapter?
Yes, that is possible. I am not sure of anything else driver related.
Zorin OS should come with all the Modules you would need.
You can try this anyway, though I doubt it will work:
sudo apt install linux-generic
