Hello Two days ago I plig in my conputer to power,a run and...run run run and i see then Bios was restart because he can't boot I click ok,I go to the bios option-without change-a save and exit and....my computer run x)
I don't know is problem is when i using timeshift i don't reutrn /boot folder or Code's BIOS: 15
My motherboard is: Gigabyte aours x670e master
My processor: AMD Ryzen 9 7950x
GPU: Nvidia Geforce RTX 3080
Memoery: 2x 16GB Kinfgton Fury
Zorin Version" 17.3
Kernel Version" 6.8.0-110-generic(but problem bigin in 6.8.0-107-generic)
Before them, I'm just using timeshift and backup my latest secury backup...
When i Reutrn to home-I make and send pictures wirh this error
yeees....I turn on my computer(but before I turn on - I connect go to the internet) and...wasn't bios error x) - I forgot wrote than when this error was - my computer dosen't connetc to internet but...why this happend?
Hi, not very clear what you are trying to say here. Usually Timeshift backs up your 'root' partition. It does not restore things like '/boot' that would be backed up with Rescuezilla when you backup the whole drive.
I understood-i ask because in option timeshift is than restore /boot not only /boot/efi
And I only restore /boot/efi ,/home i main partition but i don't check /boot and I think than when i don't restore this-this can source error with bios
